S_Reisch
Enabling a Smoother Line in Graph Builder with Local Data Filters
I'm using JMP 15 Graph Builder to plot points as well as a smoother line. When I apply a local data filter, the smoother line disappears and only the points are displayed. Is it possible to make the smoother line show up when using a local data filter?
10 REPLIES 10
S_Reisch
Re: Enabling a Smoother Line in Graph Builder with Local Data Filters
Thanks for everyone's feedback!
I downloaded 15.2.0 and I am still running into the issue.
I also still have the issue even when there are no rows hidden and no y values missing.
However I did find that if I uncheck the "Show" box in the data filter it will draw the smoother line, however then it shows the points that I would like to be filtered out.
