SpannerHead
Eliminate empty rows from a script
I have a script that builds a second script inside a JMP table, copies that and pastes it to a JMP script window to make a functional script.  Because of the nature of how this is achieved, I get a lot of empty rows in the finished script and I'd like to eliminate those.  Reformat doesn't do the trick and my attempts at REGEX and GLOBALREPLACE also fail.  Anyone succeed with this?
I looked in here for clues but I'm still not there.
Scripting the Script Editor (jmp.com)
Slán
SpannerHead
Re: Eliminate empty rows from a script
Line changing whitespace characters are not all the same which can cause some problems. Sometimes Words() can be clean option for something like this
nw = New Window("This is a script box",
	H List Box(
		Panel Box("Long Script",
			sb1 = Script Box(
				"print(\!" Hello\!");
			// comment
			// comment
			print(\!" Hello\!");",
				600,
				500
		sb2 = Script Box(, 600, 500)
// You can also clear tabs if you wish to \t (regex) or \!t (jmp)
Wait(1);
sb2 << Set Text(Regex(sb1 << get text, "[\r\n]+", "\!N", GLOBALREPLACE));
sb2 << reformat;
Wait(1);
sb2 << Set Text("");
Wait(1);
sb2 << Set Text(Concat Items(Words(sb1 << get text, "\!N"), "\!N"));
sb2 << reformat;
Wait(1);
Wait(1);
lines = sb1 << get lines;
empty = Loc(ls, "");
sb2 << Set Text(Concat Items(Remove(lines, As List(empty)), "\!N"));
sb2 << reformat;
In JMP
JSL Syntax Rules (jmp.com)
In regex (usually)
SpannerHead
Jarmo
Even better, I don't need to have parallel script windows.  I can do the elimination in a single window with this.  I nominate the present script window as ed and I'm off to the the races.  Thanks for the help.
	ed = ww[Script Box(1)];
	Wait(1);
	ed << Set Text(Regex(ed << get text, "[\r\t]+", "\!N", GLOBALREPLACE));
	ed << reformat;
Slán
SpannerHead
8 REPLIES 8
Here is one idea.  It takes a script and basically removes all line feeds and then reformats the script.
The reformatted script realigns the code
nw = New Window( "This is a script box",
sb = Script Box( "print(\!" Hello\!");
print(\!" Hello\!");", 300, 100 );
sb << Save Text( "$TEMP/Test.jsl" );
nw << close window;
intText = Load Text File( "$TEMP/Test.jsl" );
substitute into(intText,hextochar("0D"), " ");
nw = New Window( "This is a new script box",
sb = Script Box()
sb << Append Text( intText );
sb << reformat;
Level XIII
If you can live with the fact that all comments get removed as well [like in Formula Editor], you can use the magic of Char or Parse:
myScript = Char(
	Expr(
		For( i = 1, i <= 5, i++,
        // Print the value of i.
			Print( i );
    // End expression.
nw = New Window( "test", <<Type( "Script" ), myScript );
wait(0);
Main Menu( "reformat script " );
myScript = Parse( "/* Begin quote. */
    For (i = 1, i <= 5, i++,
        Print(i);
    // End expression.");
   write(myscript)
by the way: via <<Type( "Script" )
the new window is a standard Script Editor window - with the same look and feel (e.g. a play button to run the script : )
I refined my code a bit, which is not a perfect solution, but it may work
Given
It returns
// comment
// comment
nw << close window;
substitute into(intText,hextochar("0D0D"), "\!n");
substitute into(intText,hextochar("0A0A"), " ");
substitute into(intText,hextochar("2F2F"), "\!n//");
sb = Script Box()
sb << reformat;
SpannerHead
Thanks Jim and Hogi.  I'm surprised how complicated this actually is.  I had thought something that kills off incidences of double carriage returns would have worked in this case.  Maybe Regex statements work on JMP tables but not scripts?
ww = New Window( (names), << Script );
Regex( ed, "\n\n", "", GLOBALREPLACE )
Slán
SpannerHead
Level XIII
yes, sure, in JMP there are always 12 ways to do what you want to do ...
ww = New Window( "title", << Script );
new window("helper", Button Box ("clean",
mytext = ed << get text;
ed << set text(Regex( mytext, "[\n\r]{2,}", "\n", GLOBALREPLACE ))))
	H List Box(
			sb1 = Script Box(
			// comment
			// comment
				600,
				500
Wait(1);
sb2 << reformat;
Wait(1);
Wait(1);
sb2 << reformat;
Wait(1);
Wait(1);
sb2 << reformat;
In JMP
In regex (usually)
SpannerHead
Jarmo
Mighty!  Had to tinker with it a bit, seems like there was a Tab that I didn't immediately recognise.  This ended up working.
Wait(1);
sb2 << Set Text(Regex(sb1 << get text, "[\r\t]+", "\!N", GLOBALREPLACE));
sb2 << reformat;
Slán
SpannerHead
SpannerHead
Jarmo
	Wait(1);
	ed << reformat;
Slán
SpannerHead
