I have a script that reformats many files and performs some analysis producing a final summary table, however the order in which the calculations are done and new columns are added doesn't produce a very readable format.
I would like to pass the list of column names in the order I want them.
Is there a built - in way of doing this?
e.g. if I had a table with: Column 1, Column 2, Column 3, Column 4
I want to pass in the list {Column 2, Column 4, Column 1, Column 3} to the table and have the reorder the table columns to match.
