Georgios_Tsim
Dynamic Number boxes based on list items
In the following script I have a list of 3 elements and I am trying to create a new window where the user can enter some values for each of the elements:
myList = {"apple", "banana", "orange"};
nw = New Window( "Enter Numbers",
    <<Modal,
    <<Return Result,
    V List Box(
		Text Box("Enter the values"),
        For( i = 1, i <= N Items( myList ), i++,
            Lineup Box( Text Box( Eval(myList[i])),
                Number Edit Box( 42 )
        H List Box(
            Button Box( "OK" ),
            Button Box( "Cancel" )
I use the for loop because the number of the items in the list "myList" changes. So that I would like to happen also for the Number Edit Boxes. However, I get back the following:
Ideally I would like the values that the end user enters to be saved in a list.
Re: Dynamic Number boxes based on list items
Here is the approach that I would take
myVList = V List Box(
	Text Box( "Enter the values" ),
	lub = Lineup Box( N Col( 2 ), ),
	H List Box( Button Box( "OK" ), Button Box( "Cancel" ) )
For Each( {box}, myList,
	lub << append( Text Box( Eval( box ) ) );
	lub << append( Number Edit Box( 42 ) );
	<<Modal,
	<<Return Result,
	myVlist
Multiple different ways how you can do this.
You can use different methods of collecting the results, you can use XPath
fruits = {"apple", "banana", "orange"};
value_collector = V List Box(
	lub = Lineup Box(N Col(2))
For Each({fruit}, fruits,
	lub << append(Text Box(fruit));
	lub << append(Number Edit Box(42));
nw = New Window("Enter Numbers", <<Modal, <<Return Result,
	V List Box(
		value_collector,
		H List Box(
			Button Box("OK",
				vals = (lub << XPath("//NumberEditBox")) << get;
			Button Box("Cancel")
If(nw["Button"] != 1,
	Throw("Cancelled")
Show(fruits, vals);
or store the references to a list
nebs = {};
	lub << append(neb = Number Edit Box(42));
	Insert Into(nebs, neb);
	V List Box(
		value_collector,
		H List Box(
			Button Box("OK",
				vals = nebs << get;
	Throw("Cancelled")
Show(fruits, vals);
or associative array
vals = Associative Array();
	vals[fruit] = neb;
	V List Box(
		value_collector,
		H List Box(
			Button Box("OK",
				res = Associative Array(vals << get keys, (vals << get values) << get);
	Throw("Cancelled")
Show(fruits, vals, res);
With these you will have UI something like this
Or you could utilize totally different display box elements (table box and number col edit box)
	V List Box(
		Text Box("Enter the values:"),
		Table Box(
			String Col Box("Fruit", fruits),
			nceb = Number Col Edit Box("Value", J(N Items(fruits), 1, 42)),
		H List Box(
			Button Box("OK"),
	Throw("Cancelled")
show(nw["nceb"]);
	<<Modal,
	<<Return Result,
	myVlist
	V List Box(
		value_collector,
		H List Box(
			Button Box("OK",
	Throw("Cancelled")
Show(fruits, vals);
nebs = {};
	V List Box(
		value_collector,
		H List Box(
			Button Box("OK",
				vals = nebs << get;
	Throw("Cancelled")
Show(fruits, vals);
	vals[fruit] = neb;
	V List Box(
		value_collector,
		H List Box(
			Button Box("OK",
	Throw("Cancelled")
	V List Box(
		Table Box(
		H List Box(
			Button Box("OK"),
	Throw("Cancelled")
show(nw["nceb"]);
