ew_jmp
Duplicating a Graph Builder plot?
Is it possible to duplicate a Graph Builder plot/configuration?
Basically, my workflow entails setting up the axis/factors and then dropping in different [parametric] data columns to get a quick glimpse of what the boxplots/histograms look like -- I'd like to then be able to duplicate that Graph Builder window/tab and then play with other columns. My pain-point is that I have hundreds of columns, so saving me the headache of filtering and scrolling through for even two items can save me a lot of time.
I've uploaded a simplified screenshot/example of what I'm after: I'm looking for the distributions of 'size' and 'station_type' for certain data (column 'blah') and I want to create another Graph Builder window/tab with the same format so I can quickly drop a different 'blah' in.
Thanks in advance.
Re: Duplicating a Graph Builder plot?
Also check out Redo->Relaunch which shows you a launch dialog for graph builder, using a lot of the current settings. Saving the script to the script window captures all of the current settings.
Thierry_S
The simples way to scan through different columns in Graph Builder is to use the Column Switcher tool that can be found under the main GB menu > Redo > Column Switcher.
Otherwise scripting might be required if you need to automate the process further.
Best,
TS
Thierry R. Sornasse
ew_jmp
Thanks! That's the ticket! Appreciate the responses.
