jaykim
Community Trekker
Dunnett’s tests in repeated measures
I have data collected from a repeated meaures study.  Each subject's physiological data were measured eight times and 18 subjects participated in the study. The first measurement will be used as a reference value and compared with other 7 measures. So, I would like to use Dunnett's test instead of using Tukey HSD. Is there any simple way to do it?
Thanks,
Jay
ms
Super User ms
You can use the Fit Y by X platform. Set measured variable as Y, sampling (1-8, Nominal or Ordinal) as X and Subject as Block. Then under the red triangle pick "Campare Means --> With Control, Dunnett's". You will be asked to specify which level that is treated as control.
Script example:
dt = Open( "$ENGLISH_SAMPLE_DATA/Blood Pressure.jmp" );
dt << Oneway(
          Y( :BP 8M ),
          X( :Dose ),
          Block( :Subject ),
          With Control( 1, {"Control"} ),
          Comparison Circles( 1 )
ms
Super User ms
Script example:
dt << Oneway(
          Y( :BP 8M ),
          X( :Dose ),
          Block( :Subject ),
jaykim
Community Trekker
Thanks a lot!!
