jaykim
Dunnett’s tests in repeated measures
I have data collected from a repeated meaures study.  Each subject's physiological data were measured eight times and 18 subjects participated in the study. The first measurement will be used as a reference value and compared with other 7 measures. So, I would like to use Dunnett's test instead of using Tukey HSD. Is there any simple way to do it?
Thanks,
Jay
ms
Super User (Alumni) ms
You can use the Fit Y by X platform. Set measured variable as Y, sampling (1-8, Nominal or Ordinal) as X and Subject as Block. Then under the red triangle pick "Campare Means --> With Control, Dunnett's". You will be asked to specify which level that is treated as control.
Script example:
dt = Open( "$ENGLISH_SAMPLE_DATA/Blood Pressure.jmp" );
dt << Oneway(
          Y( :BP 8M ),
          X( :Dose ),
          Block( :Subject ),
          With Control( 1, {"Control"} ),
          Comparison Circles( 1 )
ms
Script example:
dt << Oneway(
          Y( :BP 8M ),
          X( :Dose ),
          Block( :Subject ),
jaykim
Thanks a lot!!
