Below is a sample data table that shows what I am trying to achieve. I want to compare means of serum levels based on a patient's mutations. The problem is some patients have multiple mutations in the same gene.
I would like JMP to recognize that the Mut1, Mut2 need to be assigned with the other mutations with the same name instead of creating its own category for them. I have tried setting the column to "Multiple Response" but then the Fit Y by X platform will not accept "Gene 1" as an X factor.
Others have suggested creating a second column for the extra mutations but then the Fit Y by X platform creates two charts and I can't analyze the means between the different mutations.
I've looked and looked for a solution, I know there has to be something simple I am missing.
