Does JMP have a test for comparing two proportions?
Does anyone know how to perform a test for one proportion and a test for comparing two proportions in JMP?
Thank you,
Naama
Re: Possible solution
I think I found some way to do this:
Both variables have to be defined as binary > analyze > Fit Y by X >
select the Y and the X variables > In the red triangle choose: two sample test for proportions
and for the one sample proportion: analyze > Distributions > choose the Y binary variable > In the red triangle :choose "test probabilities".
Are there more options to do this?
