I am sorry that I misunderstood what you were looking for. I thought other considerations would include a different design approach.
As for comparing CCD to BBD, you pretty much nailed the comparisons. For completeness I am including a JMP journal that compared the two designs using JMP's Compare Designs platform. CCD does better at detecting the main effects and interactions. The BBD does slightly better at detecting the quadratic terms. The CCD has slightly lower prediction variance in the center of the design space, but the BBD does slightly better at the edges (see the prediction profiler).
I think the design to choose will depend on your situation. Do you expect the optimum area to be near the center? Maybe go CCD. If you think it may be closer to an edge? Maybe BBD. Do you really need to worry about power for main effects and interactions with a response surface design? You probably already know the significant factors. Will running the corner points be problematic? If so, avoid BBD.
Notice that these questions are all about your process and your situation. Both designs are good designs. And, as Mark stated so well earlier, you should not rule out optimal designs. The real world limitations plus making better use of your knowledge of the process make the optimal designs very attractive and they can outperform the classic designs.
Dan Obermiller
