AlexS
Distribution not showing data in the column
Hello
I have written a Regex expression which populates data in a new column....no problem there.
the issue is when I then highlight the column and go to the ribbon and click on distribution icon sometimes the box will pop up where you select a column and other times it will go straight to the frequencies display box but both result in nothing displayed even though there is data in the column? it only happens on that particular column and it doesn't happen with other columns where I've used Regex.
Has anyone else experienced this? any solutions?
thanks
Alex is the name, Power BI/ SQL /JMP is my game
Re: Distribution not showing data in the column
Regex() returns a character string. Distribution uses a continuous numeric data column. Is the data type and modeling type consistent?
AlexS
That was correct, it was actually the fact I had some hide and exclude on some of the rows. When I reverted it back it showed everything again. Unsure why it didn't just show me rows which were not excluded though?
