FN
FN
Column filter for graph builder (Parallel plot)
The local data filter allows the user to select the rows of interest.
I wonder how I can allow the same functionality but for columns without having to edit the graph.
For example, allowing the user to select what to visualize between weight, size, age, sex...
Graph Builder(
	Size( 490, 448 ),
	Show Control Panel( 0 ),
	Variables(
		X( :age ),
		X( :sex, Position( 1 ) ),
		X( :height, Position( 1 ) ),
		X( :weight, Position( 1 ) ),
		Color( :sex )
	Elements( Parallel( X( 1 ), X( 2 ), X( 3 ), X( 4 ), Legend( 5 ) ) )
Re: Column filter for graph builder (Parallel plot)
Would Column Switcher help? You might need multiple ones and if you have duplicates in the column switchers the changing gets a bit annoying
