Or are you looking to click on the Male/Female distribution, and for it to change the values in the other graphs
Here is an example from the Scripting Index using a Data Filter Source Box
New Window( "Selection Filter",
Data Filter Context Box(
H List Box(
Data Filter Source Box(
Graph Builder(
Size( 208, 207 ),
Show Legend( 0 ),
Variables( X( :age ) ),
Elements( Bar( X, Legend( 3 ) ) ),
Dispatch(
"Graph Builder",
OutlineBox,
{Set Title( "Filter" )}
Platform(
Current Data Table(),
Bubble Plot(
X( :weight ),
Y( :height ),
Sizes( :age ),
Title Position( 0, 0 )
Here is the code adapted to the example you gave
H List Box(
Data Filter Source Box( Distribution( Nominal Distribution( Column( :sex ) ) ) ),
Platform(
Distribution(
Nominal Distribution( Column( :age ) ),
Continuous Distribution( Column( :height ) ),
Continuous Distribution( Column( :weight ) )
