matt7109
Display selected file in button box
Hi there,
I have a button that prompts user to select 2 files. However, once the user clicks the button and picks a file, I would like the path name to show up on the button so that the user knows the file was correctly selected. In the photo below, once a user picks a file, I want that selected path to show up in the highlighted area.
Current Code:
New Window( "Data and Limits file",
	<<modal,
	Text box(""),
	Text box("Choose a data file:"),
	Button Box( "Pick file", D = Pick File()),
	//Text box(L),
	Text box (""),
	Text box (""),
	Text box("Choose a limits file:"),
	Button Box( "Pick File", L = Pick File()),
	//Text box(D),
	Text box(""),
	Text box (""),
Re: Display selected file in button box
Here is the script.  The documentation on all of the features that can be used with a given function or display object is available at:
     Help==>Scripting Index
It will give you all of the details, and examples
	<<modal,
	Spacer Box( size( 10, 10 ) ),
	Text Box( "Choose a data file:" ),
	BB1 = Button Box( "Pick file",
		D = Pick File();
		If( D != "",
			BB1 << set button name( D )
	//Text box(L),
	Spacer Box( size( 20, 10 ) ),
	Text Box( "Choose a limits file:" ),
	BB2 = Button Box( "Pick File",
		L = Pick File();
		If( L != "",
			BB2 << set button name( L )
	//Text box(D),
Jeff_Perkinson
@txnelson's solution changes the text of the button, which is what the title of your post says you wanted.
But, the picture you provided looks like you want the name of the file below the button – not in the button.
If that's what you really want here's a modification of Jim's code that will get you there.
	<<modal,
		D = Pick File();
		If( D != "",
			file1 << set text( D )
	file1 = Text Box( ),
	//Text box(L),
	Spacer Box( size( 20, 10 ) );,
		L = Pick File();
		If( L != "",
			file2 << set text( L )
	file2 = Text Box(  ),
	//Text box(D),
-Jeff
	<<modal,
		D = Pick File();
		If( D != "",
	//Text box(L),
		L = Pick File();
		If( L != "",
	//Text box(D),
matt7109
Perfect!!! Thanks so much!
Jeff_Perkinson
	<<modal,
		D = Pick File();
		If( D != "",
	//Text box(L),
		L = Pick File();
		If( L != "",
	//Text box(D),
-Jeff
adam
Just an idea I thought of. From the script, understood that it allows us to open 2 files based on the path selected. Once the each file is open, how can we assign it as data table to automatically create for example a distribution(or a simple Fix Y-X) plot. Thanks.
Here are 2 simple scripts that illustrate how to create a handle to the different data tables, and then to use that handle to determine which analysis to use with what data table.
dt = Open( "$SAMPLE_DATA\iris.jmp" );
dt2 = Open( "$SAMPLE_DATA\big class.jmp" );
dt << Distribution(
	Continuous Distribution( Column( :Sepal length ) ),
	Continuous Distribution( Column( :Sepal width ) ),
	Continuous Distribution( Column( :Petal length ) ),
	Continuous Distribution( Column( :Petal width ) )
dt2 << Oneway( Y( :height ), X( :age ), Means( 1 ), Mean Diamonds( 1 ) );
dtList = {};
Insert Into( dtlist, dt );
dt = Open( "$SAMPLE_DATA\big class.jmp" );
dtList[1] << Distribution(
dtList[2] << Oneway( Y( :height ), X( :age ), Means( 1 ), Mean Diamonds( 1 ) );
adam
Thanks a lot, Jim !
