MAS
MAS
Display regression estimates' F-ratios?
Is there an option to display the F-ratio (square of the t-ratios) in the regression display of the *individual* estimates in Fit Least Squares? I know JMP displays the overall model F-stat, but I'm looking for the F-ratios for each independent variable alone.
Re: Display regression estimates' F-ratios?
In the Parameter estimates output from the Bivariate Platform, there is not a column that is available to be displayed that will show the F Ratio.  If you are using a different platform you can right click on the table box in question, select Columns and see if an F Ratio column is available to be displayed.
Regardless, you can add your own F Ratio column to the table box.  Below is a simple example of how to do thatfratio.PNG
Here is the simple script that added the F Ratio
biv = dt << Bivariate(
	Y( :height ),
	X( :weight ),
	Fit Line( {Line Color( "Medium Dark Red" )} )
// Get the t ratios
theTs = Report( biv )["Parameter Estimates"][Number Col Box( 3 )] << get;
// Convert them to F Ratio values
theTs[1] = theTs[1] ^ 2;
theTs[2] = theTs[2] ^ 2;
// Append them to the output Table Box
theTs = Report( biv )["Parameter Estimates"][Table Box( 1 )] <<
append( Number Col Box( "F Ratio", theTs ) );
I may be a bit confused, but  the F-ratios are displayed in Analysis of Variance (which provides the whole model statistics) and in the Effects Tests outputs of the Fit Model platform.  It sounds like you want the Effects Tests which decompose the model DF's into each DF.
ron_horne
Hi @MAS ,
if you are using the fit model platform with a continuous dependent variable you can get make use of the Effect tests table. This gives an F tests for each effect. for continuous variables this is identical to the t test. the same for nominal or ordinal variables with only two categories. form more than two category variable this F tests is a bit different than the individual parameter estimates.
