Thierry_S
Calculating Col Mean () for a subset of rows in JSL Script?
Hi JMP Community,
What us the proper syntax in JSL for calculating the column mean (or other statistics) for a variable defined subset of rows? In a data table, I can just used the formula "Col Mean (:Data Column, :Grouping Column)" but in a JSL script this does not seem to be a correct usage.
Of note, I'm thinking of using brute force by using a "For each row" structure but that seems quite inefficient in the evaluation of 200+ columns with 1000 rows.
Thank you for your help.
TS
Thierry R. Sornasse
Re: Calculating Col Mean () for a subset of rows in JSL Script?
I believe the simplest and most efficient way to do this is to use
     Tables==>Summary
This will create a data table very fast, from which you can get your statistics for your JSL, or if you need to have the  statistics back into the original data table, a simple Update with matching will do that.  Handling 200 columns and 1000 rows is not a problem at all.  Below is a simple example that will illustrate how to do this.
names default to here(1);
dt=Open("$SAMPLE_DATA/semiconductor capability.jmp");
colNamesLIst = dt << get column names(continuous);
dtStats = dt << Summary(invisible,
	Group( :SITE ),
	Mean( colNamesList ),
	Freq( "None" ),
	Weight( "None" ),
	Link to original data table(0)
	dt << Update(
	With( dtStats ),
	Match Columns( :SITE = :SITE )
close( dtStats, nosave );
Thierry_S
Hi JMP Community,
Here is what I have come up with using the "For Each Row" structure:
Names Default to Here (1);
dt = Current Data Table ();
ALL_MEAN = Col Mean (:DATA);
MAX_MEAN = -1000;
For Each Row (
	if (MAX_MEAN < Col Mean(:DATA, :GROUP,:SGROUP), MAX_MEAN = Col Mean(:DATA, :GROUP,:SGROUP))
Show (ALL_MEAN);
Show (MAX_MEAN);
Any idea on making this more efficient?
Thanks,
TS
Thierry R. Sornasse
     Tables==>Summary
	Group( :SITE ),
	Freq( "None" ),
	Weight( "None" ),
	dt << Update(
	With( dtStats ),
