TimG
Display Issues - Content does not update correctly
Hi Community,
I have an bug in JMP 16.2 when I scroll or switch between pages. The content does not show up right and sometimes is not updated. The images below as an example when I entered the "windows specific" settings or do some basic analysis.
Is this a known bug and does someone know how to fix that?
Many thanks in advance!
Tim
Re: Display Issues - Content does not update correctly
It should not do that. see if the information in JMP 16 not Responsive  applies to you. If that isn't it, Tech Support is your best bet.
TimG
Hi, I contacted the support and will update here if we found a Solution.
