erickskrobot
Disabling JMP Live, JMP Public and Check for Updates on preferences file
I am working on the upgrade to the version 16 of JMP in my company, and we have a preferences file that disables JMP Live, JMP Public and Check for Updates.
This is how the file looks like:
Disable JMP Server URL("*");
Disable JMP Live URL("*");
Check for Updates( 0 );
Update Check Frequency( 1 );
But testing this file with version 16 it does not seem to work, as I can still check for updates and access both JMP Live and JMP Public, and I could not find anything related on the documentation library. Did these change with this new version?
Thanks,
Re: Disabling JMP Live, JMP Public and Check for Updates on preferences file
I'm checking end-to-end now, but in 16 the option Disable JMP Live URL, needs to be in jmpStartAdmin.jsl
In your case, to disable publishing to public.jmp.com, you'd want:
Disable JMP Live URL("*public.jmp.com");
The * at the front takes care of https:// and http://
I believe you need to contact the JMP 16 test and development team on this.  Go to the Help pull down menu in JMP 16 and submit either a Bug report, or a Feedback report.
Or, contact JMP support
     support@jmp.com
