yovugaro
Difference between std error in "Parameter Estimates" and "Least Squares Means Table"?
I am running mixed effects models and have noticed that the standard error for an effect in the "Parameter Estimates" table is different from the standard error reported in the Least Squares Means table for the same effect. How are they calculated differently? Thanks!
Georg
Re: Difference between std error in "Parameter Estimates" and "Least Squares Means Table"?
Dear @yovugaro
please press "?" and click onto the table.
See links to the documentation below.
So the difference is that the one refers to parameter, and the other to each level.
Parameter Estimates (jmp.com)
Std Error
The estimates of the standard errors for each of the estimated parameters
Effect Details (jmp.com)
Std Error
Shows the standard error of the least squares mean for each level.
Georg
