XO-NANO
Determining Certainty of continuous data
I have a dataset that is comprised of multiple continuous measurements of a system. I would like to determine the bounds of certainty in my response which will then be used to create an equation to predict the input. I would like to be able to use JMP to determine the certainty bounds vs the x-axis. The attached image shows how the data appears for a portion of the dataset.
Any help would be much appreciated.
JMP
Re: Determining Certainty of continuous data
Please explore this chapter in the JMP Help system to learn about the Functional Data Explorer and then decide if this approach will satisfy your goal.
