terapin
Determine column mean by day and within certain hours
Hi Folks,
I have some hourly data and I'm trying to calculate the mean of variable x for each Day when Hour >= 1 and <=10.  I need to store this computed value in column y for each hour of each day.  I have tried Column Mean by Day where I've excluded all hours that fall outside 1 & 10, but Column Mean calculates the value for all data by Day regardless of what's been excluded.  Any suggestions on how to accomplish this using either a formula for column y or in JSL would be greatly appreciated.  Thanks
Day Hour x y
1    1    5    5.6
1    2    5    5.6
1    3    5    5.6
1    4    5    5.6
1    5    5    5.6
1    6    6    5.6
1    7    6    5.6
1    8    6    5.6
1    9    6    5.6
1    10    7    5.6
1    11    7    5.6
1    12    7    5.6
1    13    8    5.6
1    14    8    5.6
1    15    8    5.6
1    16    8    5.6
1    17    4    5.6
1    18    4    5.6
1    19    4    5.6
1    20    3    5.6
1    21    3    5.6
1    22    3    5.6
1    23    3    5.6
1    24    3    5.6
2    1    1    5.2
2    2    1    5.2
2    3    1    5.2
2    4    5    5.2
2    5    5    5.2
2    6    6    5.2
2    7    6    5.2
2    8    6    5.2
2    9    6    5.2
2    10    15    5.2
2    11    15    5.2
2    12    10    5.2
2    13    8    5.2
2    14    8    5.2
2    15    8    5.2
2    16    8    5.2
2    17    1    5.2
2    18    1    5.2
2    19    1    5.2
2    20    1    5.2
2    21    1    5.2
2    22    3    5.2
2    23    3    5.2
2    24    3    5.2
mpb
mpb
Re: Determine column mean by day and within certain hours
Don't know how efficient this is compared to other possibilities but try this as a column formula:
Col Mean( If( 1 <= :Hour <= 10, :x, Empty() ), :Day )
mpb
mpb
terapin
mpb,
Thanks. Your suggestion works great.  I tried the If statement many times, but had the wrong format for it to work properly.
