Detection of changes in a Local Data Filter
Below is a script that uses a Data Filter that when it is changed, it triggers the Row State Handler, and updates the chart.  I really want to use a local filter, but have not been able to figure out how to detect the change in the local filter.  How does one detect a change in the Local Data Filter?
dt = Open( "$SAMPLE_DATA\semiconductor capability.jmp" );
f = Function( {a},
// Capture the LCL and UCL from the Limit Summaries Outline Box in the Report Output
       myLCL = (Report( ccb )["NPN1 Limit Summaries"][Table Box( 1 )][2] << get)[1];
       myUCL = (Report( ccb )["NPN1 Limit Summaries"][Table Box( 1 )][4] << get)[1];
// Apply back to the Control Chart the new axis settings
       Report( ccb )[Axis Box( 3 )] << Min( myLCL );
       Report( ccb )[Axis Box( 3 )] << Max( myUCL );
rs = dt << make rowstate handler( f );
New Window( "Working Example",
       Data Filter Context Box(
              H List Box(
                     dt << Data Filter( Add Filter( Columns( :SITE ) ),Mode(select(1),show(1),include(1)) ),
                     Platform(dt,
                           ccb = Control Chart Builder(
                                  Size( 534, 453 ),
                                  Variables( Y( :NPN1 ) ),
                                  Chart( Position( 1 ), Limits ),
                                  Chart( Position( 2 ) ),
                                         Dispatch(
                                                "NPN1",
                                                ScaleBox,
                                                {Min( 96.6346153846154 ), Max( 131.634615384615 ), Inc( 5 ), Minor Ticks( 0 ),
                                                Add Ref Line( 104.412948990151, "Solid", "Blue", "LSL", 1 ),
                                                Add Ref Line( 131.893493064355, "Solid", "Blue", "USL", 1 ),
                                                 Add Ref Line( 118.153221027253, "Solid", "Blue", "Target", 1 )}
Sent from Mail for Windows 10
ian_jmp
Re: Detection of changes in a Local Data Filter
Perhaps you could try adding the row state handler to the local data filter? For example:
NamesDefaultToHere(1);
// Some data
dt = New Table( "Fruits",
Add Rows( 3 ),
New Column( "Fruit",
Character,
"Nominal",
Set Values( {"Pear", "Apple", "Orange"} )
// A report with a local data filter
gb = dt << Graph Builder(
Size( 528, 448 ),
Show Legend( 0 ),
Variables( X( :Fruit ) ),
Elements( Bar( X, Legend( 3 ) ) ),
Local Data Filter( Mode, Add Filter( columns( :Fruit ) ) )
// Row state handler function
doSomethingWithSelection = Function({x}, {Default Local}, Beep(); Wait(0.1); Beep() );
// Get a reference to the report
gbReport = gb << Report;
// See what messages the data filter display box understands (prints to the log)
ShowProperties(gbReport[OutlineBox(1)]);
// Assign the row state handler to the local data filter display box
rsh = gbReport[OutlineBox(1)] << MakeRowStateHandler(doSomethingWithSelection);
ms
Super User (Alumni) ms
I can't think of any built-in support for monitoring a local data filter by script.
Below is an hack that simply runs in the background to find filtering changes by the user.
f = Function( {ccb},
       Report( ccb )[Axis Box( 3 )] << Min( myLCL);
       Report( ccb )[Axis Box( 3 )] << Max( myUCL);
    nw=New Window( "Working Example",
                  H List Box(
                         ldf=dt << Data Filter( local,Add Filter( Columns( :SITE ) ),Mode(select(1),show(1),include(1)) ),
                         Platform(dt,
                                      Size( 534, 453 ),
                                      Show Control Panel( 1 ),
                                             Dispatch(
                                                    "NPN1",
                                                    ScaleBox,
// Monitor local data filtering by peeking into the Where Clause below the control Chart
// First locate the Where-clause TextBox
// (the number varies but it seems to always be the last one)
Wait(0);
i = 1;
While(Is Scriptable(Try(parent = nw[Text Box(i)] << parent)),
    While(parentType = Char(parent << className) != "OutlineBox", parent = parent << parent);
    i++;
// Scan for changes with an adequate frequency
filter = "none";
While(Is Scriptable(nw), // Will run until nw is closed
    Wait(0.1); // set the scanning frequency here
    If(!Is Missing(newfilter = Try(nw[Text Box(i)] << gettext)),
        If(filter != newfilter,
            filter = nw[Text Box(i)] << gettext;
            f(ccb); // get limits and set a axis
I was hoping there was a more direct monitor of a local filter.  Maybe 14.0 will have such a monitor. Thanks for the code.
ian_jmp
// Some data
Add Rows( 3 ),
Character,
"Nominal",
Size( 528, 448 ),
Show Legend( 0 ),
Ian,
You example worked great.  I went back to find documentation on this, in the scripting index, and only found the obscurest of reference that a "Mark Row State Handler" will work on a data table filter.  So I figured that if I set it up to be able to point directly to the filter, rather than the filter's outline box, it should work, and be an even more direct piece of code.  But that did not work.  Do you have any insight into why that doesn't work?  When I run the script, it does know that the handle "xx" is pointing to a Data Filter.
// Some data
       Add Rows( 3 ),
              Character,
              "Nominal",
       Size( 528, 448 ),
       Show Legend( 0 ),
xx = gb << Local Data Filter( Mode, Add Filter( columns( :Fruit ) ) );
doSomethingWithSelection = Function( {x},
       {Default Local},
       Beep();
       Wait( 0.1 );
       Beep();
Show Properties( gbReport[Outline Box( 1 )] );
xx << MakeRowStateHandler( dosomethingwithselection );
//rsh = gbReport[OutlineBox(1)] << MakeRowStateHandler(dosomethingwithselection);
ian_jmp
Not answering your question directly, Jim. But FWIW, I didn't see 'MakeRowStateHandler' on the list of messages for the local data filter object.
Level XII
With
rs = xx << Make Filter State Handler( dosomethingwithselection );
instead of
it will work.
Please note that it's essential to store the returned Filter State Handler to a JSL symbol: rs =
(without rs = ) will not work: Filter Change Handler
