hogi
Level XIII
Tabulate - change format?
Tabulate is great to generate an overview table with a few mouse clicks.
How can I change the format of a tabulate report in my Dashboard?
  • rotate column titles -> vertical
  • reduce font size
  • change column titles - esp: split a column title into two lines
    (unfortunately, tabulate ignores line breaks in the column names)
  • change entries (replace text)
  • make grouping entries selectable (for copy & paste)
  • add a String Col Edit Box as an additional column
  • convert to a table box
hogi
Level XIII
Re: Tabulate - change format?
same for Tables/Split which ignores everything including/after the first line break:
Names Default to Here(1);
: sex << set name("1st line \!n 2nd line");
Data Table( "Big Class" ) << Stack(
	columns( :name, :"1st line
 2nd line"n )
