I´m also a bit puzzeld about the robust Standard Deviation in the Distribution Platform.
As far as i´m concerned, the robust standard deviation is someting like IQR/1.35. This is certainly not the case here:
JMP StdDev.png Can someone explain to me, how 2E19 should be robust, if IQR is 8E-12 and median is 2E-10??
Thanks!
