pawel
Designing discrete choice survey
I have my responses data in one table, and my Choice Profiles data in the second table. I am struggling to find functionality that would be able to specify which columns from my responses (I have 9 different questions) are responsible for each row from my Choice Profiles. What is the best way to link these two?
melinda_thielba
Staff (Retired)
Re: Designing discrete choice survey
Hi, Pawel,
Usually, when you do Willingness to Pay (WTP), you use the most basic product (the one with the fewest features) as your baseline with a low price. Each line, then, is the Willingness to Pay for an "upgrade" for that feature.
The "Price Change" is what the customer is willing to pay for an upgrade, so in the attached example, you could charge $959.67 more for a larger hard drive. "New Price" is what you could charge for the whole product with the baseline settings plus that one upgrade (so, New Price - Price Change = baseline price).
The laptop example is pretty old. I'm not sure anyone would pay $950+ for a 40GB of storage these days!
It would be very helpful if you could attach a sample of the data from each of your tables.
pawel
Please see attached. I appreciate it is probably fairly basic, but I cannot find my way around it.
ian_jmp
Level X
It's probable JMP will take care of it for you. If the two tables you show were generated by 'DOE > Consumer Studies > Choice Design':
then, when you do 'Analyze > Consumer Research > Choice' you just have to select the right 'Data Format' option:
pawel
Done as requested and it helped me a lot.
I recently got to  the Willingness to Pay calculation, and have problems with interpreting the data. First of all, does the JMP SAS methodology to calculate WTP from discrete choice follow the logistics function?  Secondly, I am not sure what the New Price I got to actually represents? I started from the price of 20 as baseline and it gives me £7.58? How can i understand it? Do you have any defintion of it?
Thank you for your prompt replies, I found them very useful.
Phil_Kay
http://www.jmp.com/support/help/13-2/Willingness_to_Pay.shtml#453057
http://www.jmp.com/support/help/Valuing_Trade-offs.shtml
Hi Pawel,
These links should be useful. In addtion, try searching "willingness to pay" in the community.
I hope this helps.
Phil
melinda_thielba
Staff (Retired)
Hi, Pawel,
