masum111bd
Deleting multiple columns based on column name
Hi ,
I want to delete multiple columns based on some specific strings they contain in column name. I can do it for single name. But for multiple name it does not work.
col_list = dt << get column names(string);
for (i = nitems(col_list), i > 0, i--,
if (contains(col_list[i], "SAVED_IMAGES", "sw_", "HH"),
remove from(col_list, i);
Shows this error
col_list = dt << get column names( string );
For( i = N Items( col_list ), i > 0, i--,
If( Contains( col_list[i], "SAVED_IMAGES", "SS_EID" ),
Remove From( col_list, i )
ih
ih
Re: Deleting multiple columns based on column name
If I understand your question you want to iterate through both the column names and the strings to match:
remove_strings = {"SAVED_IMAGES", "sw_", "HH"};
//for each column name
	//for each string to match
	for( j = 1, j <= N Items( remove_strings ), j++,
		//if it matches remove the item
		if( contains( col_list[i], remove_strings[j] ) > 0,
I believe the structure you need to use for your comparison is:
if (contains(col_list[i], "SAVED_IMAGES") & contains(col_list[i], "sw_")  &
contains(col_list[i], "HH"),
ih
ih
masum111bd
This script deletes  columns that contain those names in columns. What should I do if I want to keep only
those specific coulmns (contains those names) and delete other columns?
Here is how I would do it
	If(
		Not(
			Contains( col_list[i], "SAVED_IMAGES" ) | Contains( col_list[i], "sw_" ) |
			Contains( col_list[i], "HH" )
Article Labels
