matteo_patelmo
Deleting display boxes
following suggestions from txnelson from a previous post, I'm creating a few display boxes without showing them in a window, in order to extract the informations I need with not visualizations for the user.  I am not sure, though, if I need to delete these display boxes explicitly or if some garbage collection is active to delete them at some time.
If I do need to delete them, is boxName<<delete box  the correct way?
thanks
Matteo
matteo_patelmo
Re: Deleting display boxes
Thanks. Could you please explain what to do with vlb in your example? is this display box taking up memory as well? I suppose it gets closed automatically with the << close window message, but it's not very clear how this happens.
What about an empty V List Box created but not shown in any window, like:
vlb=V List Box();
Should it be deleted? how?
Any object created takes up memory, if it is visible or not.  So it is wise to clean up any created objects.  Here is what I do for both visible and invisible platforms.
dt = Open( "$SAMPLE_DATA/big class.jmp" ,private);
vlb = V List Box( biv = dt << bivariate( x( :height ), y( :weight ) ) );
biv << close window;
matteo_patelmo
vlb=V List Box();
vlb can be deleted, but it is a very small object by its self.
vlb<<delete;
