ozs02
Deleting Specific Column after closing Graph Builder
Currently I have code that populates a data table with a new column containing a formula. This column is then used as overlay in graph builder.
I was wondering if there is a way to delete this column (with the formula) once the user exits out of the graph builder. Thank you for the help!
Names Default To Here (1);
// first program
program1 = function({},
	show("formula 1");
// JSL code
dt << New Column("Bin", Character, formula(If( /*formula code*/)));
// second program
program2 = function({},
	show("formula 2");
// JSL code
// third program
program3 = function({},
	show("formula 3");
// JSL code
// fourth program
program4 = function({},
	show("formula 4");
// JSL code
//window that allows users to press button to generate graph with state ID labels based on protocol type
nw = new window("Program Options", << modal,
	panel box("Click the button to run the desired program",
		lineup box(ncol(1),
			SpacerBox(),
			b1 = button box("program 1",
				program1();
				okBtn << Click();
			b2 = button box("program 2",
				program2();
				okBtn << Click();
			b3 = button box("program 3",
				program3();
				okBtn << Click();
			b4 = button box("program 4",
				program4();
				okBtn << Click();
	h list box(SpacerBox(),okbtn = Button Box("Cancel"), SpacerBox())
//make graph
gb = dt << Graph Builder (
		//time, volume, bin are column names
		Variables( X( :Time ), Y( :Volume ), Overlay( :Bin )),
		Elements
			Points
				X, Y, Legend( 9 )
		Categorical Color Theme("JMP Vibrant");
reportWindow = gb << Report;
Re: Deleting Specific Column after closing Graph Builder
You need to use the On Close() function
Here is an example
names default to here(1);
dt=open("$sample_data/big class.jmp");
dt<<new column("x", formula(:height/:weight));
gb = Graph Builder(
	Size( 534, 456 ),
	Variables( X( :x ), Y( :weight ) ),
	Elements( Points( X, Y, Legend( 3 ) ), Smoother( X, Y, Legend( 4 ) ) )
gb << on close(dt<<delete columns("x"));
You can add <<On Close() to the graph builder window which will delete the column. Example with Big Class, will delete sex column when graph builder is closed
gb = dt << Graph Builder(
	Size(535, 451),
	Show Control Panel(0),
	Variables(X(:age), Y(:weight), Overlay(:sex)),
	Elements(Points(X, Y, Legend(13)))
gb << On Close(dt << Delete Column("sex"));
Here is an example
gb = Graph Builder(
	Size( 534, 456 ),
ozs02
Thank you! Exactly what I needed!
	Size(535, 451),
ozs02
Thanks! This is perfect!
