Katz0801
Deleting Duplicate Scripts
I have concatenated multiple files into a database which has lead to a database with many duplicated scripts. Is there a way to write a script to remove duplicated scripts? I don't want to delete them manually as I will add more files to the database with concatenation in the future which would again add the scripts to the file.
Katz0801
Re: Deleting Duplicate Scripts
Update - I solved it using this method:
dt = Current Data Table();
names = dt << Get Table Script Names;
Show(names);
wordsToDelete = {"Script 1 name", "Script 2 name", "Script 3 name"};
For(i = 1, i <= N Items(names), i++,
    scriptName = names[i];
    containsWord = 0;
    For(j = 1, j <= N Items(wordsToDelete), j++,
        word = wordsToDelete[j];
        If( Contains( scriptName, word ),
            containsWord = 1;
            Break();
   If( containsWord,
        dt << Delete Scripts( scriptName );
You can use Get Table Script Names to get names of all table scripts. Then you can filter that down to a list of scripts you wish to remove and finally delete them with << Delete Scripts
Show(names);
dt << New Table Script(
	"New Script",
	Distribution(Column(:Height, :Weight), By(:sex))
Wait(2);
dt << Delete Scripts("New Script");
Katz0801
Show(names);
    containsWord = 0;
            containsWord = 1;
            Break();
   If( containsWord,
