joelahn
Deleting Column Formula error by using Delete Property (formula) script.
I have multiple columns with formula, and I wanted to remove formula after calculations.
codes are as below.
cols = dt << get column names();
For( i = 1, i <= N Col( dt ), i++,
    cols[i] << Delete Property( formula )
Then, the log says the following:
Send Expects Scriptable Object in access or evaluation of 'Send' , cols[i] <<  /*###*/Delete Property( formula ) /*###*/
Can somebody help on me this?
Another question is if we can make a list of specific columns and delete formula.
We have a script called "Delete Formula", I wanted to use this to column list, but it seems it's not working well.
Joel Ahn
Lam Research Corporation
Mobile +82 10 9509 0109
joelahn
Re: Deleting Column Formula error by using Delete Property (formula) script.
    As Columns( cols[i] ) << Delete Property( formula )
Putting As Column() has resolved this. Yet I still have wonders why it did work a few times, then later on it didn't work - with same JMP versions (I use both 15, and 16EA).
Joel Ahn
 column(cols[i]) << Delete formula;
//or
 column(i) << Delete formula;
