ealindahl
Delete strings in a list that contain a word
I have a list of file names from which I want to select certain files. The first 4 digits are the year the underscore is acting like a deliminater, the "abc" is just an identifier for the type of file, the 3 digit number is the id, and "summary" or "result" refer to the kind of file.
First, I only want to look at the "result" files. I couldn't figure out how to remove all the "summary" files from my list.
{"2021_abc_027_result.csv", "2021_abc_027_summary.csv", "2021_abc_028_result.csv",
"2021_abc_028_summary.csv", "2021_abc_029_result.csv", "2021_abc_029_summary.csv",
"2021_abc_038_result.csv", "2021_abc_038_summary.csv", "2021_abc_040_result.csv",
"2021_abc_040_summary.csv", "2021_abc_041_result.csv", "2021_abc_041_summary.csv",
"2021_abc_042_result.csv", "2021_abc_042_summary.csv", "2021_abc_043_result.csv",
"2021_abc_043_summary.csv", "2021_abc_044_result.csv", "2021_abc_044_summary.csv",
"2021_abc_045_result.csv", "2021_abc_045_summary.csv", "2021_abc_046_result.csv",
"2021_abc_046_summary.csv", "2021_abc_047_result.csv", "2021_abc_047_summary.csv",
"2021_abc_048_result.csv", "2021_abc_048_summary.csv", "2021_abc_049_result.csv",
"2021_abc_049_summary.csv", "2021_abc_050_result.csv", "2021_abc_050_summary.csv",
"2021_abc_051_result.csv", "2021_abc_051_summary.csv", "2021_abc_052_result.csv",
"2021_abc_052_summary.csv", "2021_abc_053_result.csv", "2021_abc_053_summary.csv",
"2021_abc_054_result.csv", "2021_abc_054_summary.csv", "2021_abc_055_result.csv",
"2021_abc_055_summary.csv", "2021_abc_056_result.csv", "2021_abc_056_summary.csv",
"2021_abc_057_result.csv", "2021_abc_057_summary.csv", "2021_abc_058_result.csv",
"2021_abc_058_summary.csv", "2021_abc_059_result.csv", "2021_abc_059_summary.csv",
"2021_abc_060_result.csv", "2021_abc_060_summary.csv", "2021_abc_061_result.csv",
"2021_abc_061_summary.csv", "2021_abc_062_result.csv", "2021_abc_062_summary.csv",
"2021_abc_063_result.csv", "2021_abc_063_summary.csv", "2021_abc_064_result.csv",
"2021_abc_064_summary.csv", "2021_abc_065_result.csv", "2021_abc_065_summary.csv",
"2021_abc_067_result.csv"}
Second, I want to select the files based on the year and 3 digit code.
I have done something similar in the past to select files using regex where there was only one number in the string so I used
For( i = 1, i <= N Items( FileList ), i++,
	FileList[i] = regex(FileList[i], "([0-9]+)", "\1")
but in this case I end up with a list of "2021", "2021",...
Ideally I would end up with a list looking like
{"2021_027 ", "2021_027 ", "2021_028 ",
"2021_028 ", "2021_029 ", "2021_029 ",
"2021_038 ", "2021_038 ", "2021_040 ",
"2021_040 ", "2021_041 ", "2021_041 ",
"2021_042 ", "2021_042 ", "2021_043 ",
"2021_043 ", "2021_044 ", "2021_044 ",
"2021_045 ", "2021_045 ", "2021_046 ",
"2021_046 ", "2021_047 ", "2021_047 ",
"2021_048 ", "2021_048 ", "2021_049 ",
"2021_049 ", "2021_050 ", "2021_050 ",
"2021_051 ", "2021_051 ", "2021_052 ",
"2021_052 ", "2021_053 ", "2021_053 ",
"2021_054 ", "2021_054 ", "2021_055 ",
"2021_055 ", "2021_056 ", "2021_056 ",
"2021_057 ", "2021_057 ", "2021_058 ",
"2021_058 ", "2021_059 ", "2021_059 ",
"2021_060 ", "2021_060 ", "2021_061 ",
"2021_061 ", "2021_062 ", "2021_062 ",
"2021_063 ", "2021_063 ", "2021_064 ",
"2021_064 ", "2021_065 ", "2021_065 ",
"2021_067 "}
and then I could select from that list the files I want to use.
Also any tips on learning how to regex better are welcome.
Thank you!
Thierry_S
Re: Delete strings in a list that contain a word
Here is a brute force approach to your problem that bypass the need to use regex (I'm not too good with those).
Names default to Here (1);
StartList = {"2021_abc_027_result.csv", "2021_abc_027_summary.csv", "2021_abc_028_result.csv",
"2021_abc_067_result.csv"};
ResultList = {};
For (i = 1, i <= N Items (StartList), i++,
	if (contains (StartList [i], "result"), insert into (ResultList, StartList[i]))
Show (ResultList); // Yields a clean list with results only
FileList = {};
For (i= 1 , i <= N Items (ResultList), i++,
	Insert into (FileList, Word (1, ResultList [i], "_") || "_" || Word (3, ResultList [i], "_"))
Show (FileList); // Yields the file Year and Numerical ID
You can then use that list to feed into a ListBox or directly retrieve the corresponding file with the Contains () function.
I'll read more about regex for the next time.
Best,
TS
Thierry R. Sornasse
Georg
Here's one regex approach:
Assign(
	file_lst,
	{"2021_abc_027_result.csv", "2021_abc_027_summary.csv", "2021_abc_028_result.csv", "2021_abc_028_summary.csv", "2021_abc_029_result.csv",
	"2021_abc_029_summary.csv", "2021_abc_038_result.csv", "2021_abc_038_summary.csv", "2021_abc_040_result.csv", "2021_abc_040_summary.csv",
	"2021_abc_041_result.csv", "2021_abc_041_summary.csv", "2021_abc_042_result.csv", "2021_abc_042_summary.csv", "2021_abc_043_result.csv",
	"2021_abc_043_summary.csv", "2021_abc_044_result.csv", "2021_abc_044_summary.csv", "2021_abc_045_result.csv", "2021_abc_045_summary.csv",
	"2021_abc_046_result.csv", "2021_abc_046_summary.csv", "2021_abc_047_result.csv", "2021_abc_047_summary.csv", "2021_abc_048_result.csv",
	"2021_abc_048_summary.csv", "2021_abc_049_result.csv", "2021_abc_049_summary.csv", "2021_abc_050_result.csv", "2021_abc_050_summary.csv",
	"2021_abc_051_result.csv", "2021_abc_051_summary.csv", "2021_abc_052_result.csv", "2021_abc_052_summary.csv", "2021_abc_053_result.csv",
	"2021_abc_053_summary.csv", "2021_abc_054_result.csv", "2021_abc_054_summary.csv", "2021_abc_055_result.csv", "2021_abc_055_summary.csv",
	"2021_abc_056_result.csv", "2021_abc_056_summary.csv", "2021_abc_057_result.csv", "2021_abc_057_summary.csv", "2021_abc_058_result.csv",
	"2021_abc_058_summary.csv", "2021_abc_059_result.csv", "2021_abc_059_summary.csv", "2021_abc_060_result.csv", "2021_abc_060_summary.csv",
	"2021_abc_061_result.csv", "2021_abc_061_summary.csv", "2021_abc_062_result.csv", "2021_abc_062_summary.csv", "2021_abc_063_result.csv",
	"2021_abc_063_summary.csv", "2021_abc_064_result.csv", "2021_abc_064_summary.csv", "2021_abc_065_result.csv", "2021_abc_065_summary.csv",
For( i = 1, i <= N Items( file_lst ), i++,
	print( eval(Regex( file_lst[i], "^([0-9]+)_([a-z]{3})_([0-9]{3}).*result", "Fullname: \0 Part1: \1 Part2: \2 Part3: \3" )) )
Georg
gzmorgan0
Here is another approach.  I like to use the RegexMatch(SourceStr, patStr) function.  dot asterisk (.*) is similar to using a % in a Like database function.  Since you wish to remocve items from your list, you need to start from the end of the list otherwise your index is corrupted.
Names Default to Here(1);
FileList = {"2021_abc_027_result.csv", "2021_abc_027_summary.csv", "2021_abc_028_result.csv",
    patStr = "2021.*result.*";
    For(i = nitems(FileList), i>=1, i--,
        SourceStr = FileList[i] ;
		ret = Try( Regex Match( SourceStr, patStr )[1], "" );
		If( ret != SourceStr, RemoveFrom(FileList,i) );
	); //end For i
	Show(FileList);
Three high quality solutions:
@Thierry_S - easy to understand and maintain
@Georg - exactly how regex replacement is used
@gzmorgan0  - efficient removal from a list by working backwards
You can mix-and-match these ideas to make an ideal solution that is easy to maintain, efficient, and clearly represents the problem you are solving.
