OneNorthJMP
Delete columns with same value
I run into problem when i run my model with some parameters. So i want to do some data cleaning before run the model. Is there a quick way to delete columns with same values? Please advise how to do it with JSL or any other way that may fit?
OneNorthJMP
Re: Delete columns with same value
Georg, thanks for the columns viewer idea.
I think i will do that with columns viewer -> Summary -> sort the table by stdev = 0. Then i can remove the columns later.
14 REPLIES 14
Georg
I'm not sure if I get you Right,
for modelling you can select the columns that you think are important, so there is no Need to delete the column.
You want to delete some rows where a column has the same value?
Below is the Code for it:
Otherwise please describe more in Detail what you Need, an example May be very helpful.
wait(3);
dt << Select duplicate rows( Match( :age ) );
dt << delete rows;
Georg
OneNorthJMP
I don't want to delete rows. I want to delete columns that have same value.
Georg
This one deletes columns:
// make some copies of columns
dt << New Column( "weight_copy", set each value( :weight ) );
dt << New Column( "height_copy", set each value( :height ) );
to_delete_lst = {};
For( i = 1, i < N Col( dt ), i++,
	For( j = i + 1, j <= N Col( dt ), j++,
		If( (Column( i ) << get data type) == (Column( j ) << get data type),
		// all celles are equal ?
			If( Mean( (Column( i ) << get values) == (Column( j ) << get values) ) == 1,
				Print( (Column( i ) << get name) || " equal to " || (Column( j ) << get name) );
				insert into(to_delete_lst, j);
// show list of equals
Show(to_delete_lst);
wait(3);
dt << select columns(to_delete_lst);
dt << delete columns;
Georg
OneNorthJMP
Thanks for JSL. But i am not sure it does what i want.
Georg
I'm not sure, too
This means, you Need to be more specific on what you Need.
If you simply want to explore the values of a large table, you May want to use the columns viewer
Columns->Columns viewer
There you easily can compare columns of a large table.
Georg
OneNorthJMP
Here is a different take on how to do this.  It uses RSquare as an indicator of matching data.
colNames = dt << get column names( continuous );
obj = dt <<
Response Screening(
	Y( Eval( colNames ) ),
	X( Eval( colNames ) )
dtCalc = obj << get PValues;
dtCalc << select where(Round(:RSquare,4) != 1 | :X == :Y );
try( dtCAlc << delete rows );
dtCompare = dtCalc << subset( selected rows(0), columns("X","Y"));
close(dtCalc,nosave);
for each row(
	If(:X > :Y,
		hold=:X;
		:X = :Y;
		:Y = hold;
dtFinal = dtCompare << Summary(
	Group( :X, :Y ),
	Freq( "None" ),
	Weight( "None" ),
	Link to original data table( 0 )
close( dtCompare, nosave );
OneNorthJMP
Hi nelson,
Thanks for advice.  But the response screening is take way too much processing time and it is not ideal. Running 45s and haven't half way finish processing.
Thierry_S
Based on this later post, I think we did not understand the statement of "same values"; we interpreted as column 1 = column 2 for each row but I surmise that you mean any column with identical values in each row (i.e. 0 StdDev). Is that correct?
If it is, I or somebody more experience that I am should be able to provide a relatively short script.
Best,
TS
Thierry R. Sornasse
Article Labels
