rs
rs
Null hypothesis - JMP Custom test
Hi All,
I am fitting  a fourth degree polynomial to a dataset.  The equation is.
y = b0 +b1x+ b2x^2 + b3x^ + b4x4 + e
Typically, we null tested is "Ho: b1=b2=b3=b4=0"
However, I want to test if the coefficients are not zero "Ho: b3=b4=0"
How do we do this using JMP 15 custom test?
Thanks
Re: Null hypothesis - JMP Custom test
You should do a search on this community discussion board for "custom test". There have been several discussions on how to set up the custom test. Here is one of them: Fit Model - Custom Test and this discussion links to another really good discussion.
Dan Obermiller
