gallardet
Delete all columns that have zeros in all raws
Well, that is what I need to do.
I tried to look for similar scripts but I have not found the solution.
Thanks in advance.
Manel
Re: Delete all columns that have zeros in all raws
Here is a simple script that will delete all columns that are all zeros
numericColNames = dt << get column names( string, numeric );
allZerosList = {};
For( i = 1, i <= N Items( numericColNames ), i++,
	If( Col Sum( Column( dt, numericColNames[i] ) ) == 0
	& Col Std Dev( Column( dt, numericColNames[i] ) ) == 0,
		Insert Into( allZerosList, numericColNames[i] )
If( N Items( allZerosList ) > 0,
	dt << delete columns( allZerosList )
ron_horne
allZerosList = {};
gallardet
Thanks, Sir.
TRR21
Can this be tweaked such that I can remove columns that have mostly zeros (eg. 50% of more of the rows)?
Thanks.
You could do something like:
If(
	N Rows( dt << get rows where( Column( dt, numericColNames[i] ) == 0 ) ) >
	N Rows( dt ) / 2,
