rshehadah
Delete Duplicate rows
I have a datable that I want to delete rows on a duplicate value in a col.
Thank you,
Rami
Re: Delete Duplicate rows
Select Duplicat Rows() function will highlight rows for a specified column(s)
dt <<
Select duplicate rows( Match( :name ) );
xx=dt<<get selected rows;
if(n rows(xx)>0,
	dt<<delete rows;
Hi Rami,
Jim's script is a nice option, but if you have JMP 14 you can also select duplicate rows in a column by point and click.
Highlight the column of interest, go to the Rows dropdown or red hot spot.  Rows > Row Selection > Select Duplicate Rows.  All of the duplicate values will be highlighted in by row number.  Right click anywhere in the blue region and select delete.
HTH
Bill
dt <<
if(n rows(xx)>0,
	dt<<delete rows;
Hi Rami,
HTH
Bill
lwx228
Level VIII
It is recommended that JMP continue to improve to enable all automation with JSL.Thank you very much!
ENTHU
I have a data table which has column called Part_number.I need to remove duplicate part_numbers.The delete duplicate rows options suggested above deosnt work as in no rows get selected.The column is character,nominal type.I'm using JMP12.
Any other options that I can try?
Also does this function retain the first row and delete the repititions as in Excel?
Thanks
The Select Duplicate Rows() function was not in JMP 12.  The below code should do what you want
dt = Open( "$SAMPLE_DATA\Big Class.JMP" );
dt << sort( by( :Part_number ), order( ascending ), Replace Table( 1 ) );
dt << New Column( "dup",
	formula(
		If(
			Row() == 1, value = 1,
			:Part_number != Lag( :Part_number ), value = 1,
			value
			value;
dt << select where( :dup > 1);
dt << delete rows;
dt << delete column( "dup" );
CanhKhong
Thanks Bill for the tip/trick.
I sometimes have duplicate rows but struggle how to delete them. Just thinking about JMP Community and it helps to solve the issue.
