LukeFarrell
Delete Character from String In specific position
I am looking to create a script to remove a character from a string while ignoring the same character earlier in the string.
For example, from a data table I have a special DateTime of YY/MM/DD/hh:mm and wish to remove the third / (ie character 9).
Thank you for any help,
Luke
~ Luke :)
Re: Delete Character from String In specific position
There are many approaches. If the strings are always the same length, etc, I might use a formula column with
Left( DateTime, 8 ) || "T" || Right( DateTime, 5 );
You might want a separator like T which is used by one of the international formats, yyyy-mm-ddThh:mm.
If there is some variation, but maybe always the third /, I might use regex in the formula column
Regex( DateTime, "^(\d+/\d+/\d+)/(\d+:\d+)$", "\1T\2" );
^ and $ anchor the match to the beginning and end of the DateTime string. \d+ matches 1 or more digits. The parens make groups, and the two groups are referenced with \1T\2 to build the result value.
LukeFarrell
Hello Craige, I have tried that but seem to be getting errors when trying to use it:
I may be understanding it incorrectly as I am attempting to create a new column with the data:
Also apologies, for some reason I was unable to send as a JLS script to required screencap
~ Luke :)
Could be just some simple mistake with column references.
dt = New Table("Untitled 5",
	Add Rows(3),
	New Column("DateTime", Character, "Nominal", Set Values({"21/10/24/15:21", "21/10/24/14:21", "20/09/20/15:20"}))
other solutions
a = "21/10/24/15:21";
//other solution with Regex
Show(Regex(a, "^(.{8})(.)(.*)$", "\1 \3"));
//using Words and Concat Items
Show(Concat Items(Words(a, "/")[1 :: 3], "/") || " " || Word(4, a, "/"));
//Using Contains to get last "/" and then Substr()
lastIdx = Contains(a, "/", -1);
Substr(a, 1, lastIdx - 1) || " " || Substr(a, lastIdx + 1);
dt << New Column("Compatible DateTime", Formula(Left(:DateTime, 8) || " " || Right(:DateTime, 5)));
(Note that the new column won't be Numeric Continuous without some extra jsl)
