- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Get Direct Link
Date Conversion issue
I have a set of data from a database that represents a date in an 8-number string "CreatedDateDimID" in the screen capture. I need it to be formatted like the date in "SterlingDimDate.Date"
I tried converting to m/d/y in the column info, but it doesn't convert it correctly (see screen capture). What am I missing?
Gives me this result when I would expect 01/03/2022 for the first one and 04/13/2022 for the second one;
I need to be able to capture the delta between the two dates.
-Phil
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
Re: Date Conversion issue
I think you might have to change the column to Character column, press apply (and possible even OK), then go back to column properties, set column to numeric continuous, set correct format and then press apply.
Numeric
Character
Back to numeric with formatting
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
Numeric
Character
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
Thanks! That worked perfectly.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
I'm trying to build this into JSL and I can't seem to get the last step to work..
It doesn't seem to respect the Input Format.. I'm certain my code is wrong.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
If I were to do this with scripting I would use different method. One option would be to use Informat:
dt = New Table("Untitled",
Add Rows(1),
New Column("Col", Numeric, "Continuous", Format("Best", 12), Set Values([20220103]))
wait(1);
Column(dt, "Col") << Set Each Value(Informat(Char(:Col), "YYYYMMDD"));
wait(1);
Column(dt, "Col") << Format("m/d/y", 12);
