jueefo
Datatable script to get data on the original datatable
I have created an empty datatable and a script in it. The script gets data from the database, but it will open a new datatable for the data.
Is it possible and how to open the data in the original datatable which has the script?
The JMP version used 15.2 is.
ih
Super User (Alumni) ih
Re: Datatable script to get data on the original datatable
Is there a reason you want the original script in a datatable?  You could save your script as a .jsl file and have that open the new data and add any new columns/scripts to it.  You can also have the script run automatically and close itself after the table is created.
If there is another reason to run it from a table, you can concatenate or join the new data back to your original table.
dtCurrent = Current Data Table();
dtNew = Open( .. some database query ..);
dtCurrent << Concatenate( dtNew, Append to first table );
dtNew << Close Window;
ih
jueefo
Thanks, that works!
The question why to use a datatable instead of the .jsl file is very good. And I do not have a good answer. I am just starting with jsl-scripts, so I might be using not so good methods. I will rethink how to do this.
