tom_abramov
Level V
Data Table to Table Box
I would like to send a data table to my report and close the table.
So, Data Table Box is not good - a table in the report disappears.
Is there some quick way to create simple not linked Table Box from Data table?
Thank you,
Tom.
Re: Data Table to Table Box
Sending the Get As Report message to the data table will return a TableBox of the data table without any links to the original table.
dt = Open( "$SAMPLE_DATA\Big Class.jmp" );
nw = New Window( "Big Class",
	dt << Get As Report()
Close( dt, NoSave );
Justin
Tina
Hi Tom,
if you are working with a journal you could try
Current Data Table() << Journal;
to print it to the journal and to close it afterwards:
Close(dt,NoSave);
Best,
Tina
Justin
tom_abramov
Level V
Thank you,
Exactly what I need.
johnmoore
Justin,
This is exactly what I need. Many thanks!
John
