laisteve17
Data Table from Private to Visible
How do I show (in a window) a data table that was opened as Private?
I understand that private objects do not have windows associated with them. I generate many tables and I am optimizing my script by keeping them private. My question is, how do I add a private data table to a window and display it like a typical data table? I want the same functionality as if it were opened as Visible.
Thank you in advance!
Eric_Hill
Re: Data Table from Private to Visible
Hey,
Specifically to Jim's point, do this:
dtPrivate = Open("$SAMPLE_DATA\Big Class.jmp", Private);
dtVisible = dt << Subset( Link To Original Data Table(1) );
Any changes you make to the visible version of the table will be reflected in the private table, since the visible table is merely a link to the private table.
HTH,
Eric
You will have to create a subset of the data table to either an invisible or visible state.
Eric_Hill
Hey,
HTH,
Eric
This can be done without creating a subset using the New Data View message. I used this method in my Word Import Tool add-in.
dt = Open( "$SAMPLE_DATA\Big Class.jmp", "private" );
dt << New Data View;
Justin
