mallen810
Daily Average and Max and Min for a given date
I am importing sql data for our server and there can me several readings on any given day. I want to be able to get the daily average, max and min for a given day. If possible I would like to graph the data in this way also.
Re: Daily Average and Max and Min for a given date
After reading your data into JMP, you can run
     Analyze==>Tabulate
to get the report table you asked for
And then to get the graph
     Graph==>Graph Builder
to generate box plots, that show the distribution for each date
mallen810b.GIFmallen810b.GIFDocumentation you should look at is located under the Help pull down menu
     Help==>Books==>Using JMP
and
     Help==>Books==>Essential Graphing
Make sure the format specified is for a Date format, and not a DateTime format.  And If necessary, create a new column with a formula pulling out only the date part of your column, and then use it as the column in the tabulate.
If you attach your jmp table to your response, I will take a look at it.
     Analyze==>Tabulate
and
mallen810
Tabulate only give me the average for all the data and not for individual days.
You need to change the Modeling Type of your date column from Continuous to Ordinal
mallen810
I changed the modeling but still returning more than one average number per day.
mallen810
Thanks, when I mad new column and extracted only the date it worked perfect.
