frankderuyck
DOE ANALYSIS PROFILER
When analyzing a DOE with a categorical factor/settings A,B & C using STEPWISE in the profiler I get combinations of the factor settings A-B, B-C.. This gives a difficult inerpretation. How can I get in the Stewaise analysis profiler the pure factor settings A,B & C like in the analysis with standard least squares or JMP Pro generalized regression?
Re: DOE ANALYSIS PROFILER
You cannot do it from the Profiler because that is the effect that Stepwise found. You might want to use Stepwise again but change your Rules to "Whole Effects". That will prevent these A-B and B-C factors from appearing.
Dan Obermiller
Dan Obermiller
frankderuyck
Works fine, thanks Dan!
frankderuyck
It works fine with stepwise however I get the same problem when selecting all possible models?  pity I would like to use it in a training for people who don't have all the JMP pro but this way it is not possible..
