See how to use to use Text Explorer to glean valuable information from text data at April 25 webinar.
Customise value colours in columns
matth1
I have a numeric column called Rejects which is set to be nominal. Most of the values are zero but there are also a range of values from 1 to N (N being variable depending on the dataset). I use these to plot a map of reject locations with the number of rejects indicated by colour.
I would like take advantage of the JMP built-in chromatic colour themes but with any value of 0 shown in light grey (so it's easy to see where there are rejects). However, I can't do both.
I tried:
dt:Rejects << Set Property( "Value Colors", Color Theme( "Jet" ) );
dt:Rejects << Set Property( "Value Colors", {0 = 32} );
but the second command overrides the first and sets the color theme back to the default. I can do it interactively by setting the colour theme then clicking on the colour for 0 in the column properties dialog but I want to script it.
I could change the default catagorical colour threme to be Jet, but I don't want to rely on that, and I also just other colour themes elsewhere in my reports. I also don't want to hardcode the colours because I want to use the full range of colours (blue to red) whether N is 5 or 25.
Many thanks for your help,
Matthew.
ian_jmp
Level X
Re: Customise value colours in columns
Something like this, perhaps?
NamesDefaultToHere(1);
// Make a table with defect counts
dt = NewTable("Defects", NewColumn("Rejects", Numeric, Ordinal, Formula(RandomInteger(0, 5))));
dt << addRows(30);
dt << runFormulas;
// Set some default colours . . .
// Make a graph
gb = dt << Graph Builder(
				Size( 529, 447 ),
				Variables( X( :Rejects ), Color( :Rejects ) ),
				Elements( Bar( X, Legend( 5 ) ) )
// Get the default colors
defaultColours = dt:Rejects << getProperty("Value Colors");
// Update the colour for 0 defects
Wait(2);
defaultColours[1] = Expr(0 = 32);
// Renistate updated colours
dt:Rejects << Set Property( "Value Colors", defaultColours);
ian_jmp
Level X
dt << addRows(30);
dt << runFormulas;
// Make a graph
				Size( 529, 447 ),
Wait(2);
matth1
Thanks Ian, works well!
Regards,
Matthew.
