Jackie_
Custom shade alternate rows in table box
Is there a way to custom-shade alternate rows for the table box, not the data table box?
I want to shade green instead of dark gray
New Window( "Mountains",
	tb = Table Box(
		String Col Box( "Mountain", {"K2", "Delphi", "Kilimanjaro", "Grand Teton"} ),
		Number Col Box( "Elevation (meters)", {8611, 681, 5895, 4199} )
Re: Custom shade alternate rows in table box
I don't think you can do it directly with Table Box. You could do the coloring by datatable (example of this below) or col box
dt = New Table("Untitled",
	Add Rows(4),
	Compress File When Saved(1),
	New Column("Mountain", Character, "Nominal", Color Cells({44, {2, 4}}), Set Values({"K2", "Delphi", "Kilimanjaro", "Grand Teton"})),
	New Column("Elevation (meters)", Numeric, "Continuous", Format("Best", 12), Color Cells({44, {2, 4}}), Set Values([8611, 681, 5895, 4199]))
nw = New Window("",
	dt << get as report
	Add Rows(4),
nw = New Window("",
	dt << get as report
Jackie_
This works. Thanks Jarmo
see Custom Table Calculator . I think it used to work better, I had to play with the color just now in JMP 18 to see any green.
<<backgroundcolor( RGB Color( 235, 255, 235 ) )
worked better than
<<backgroundcolor( RGB Color( 245, 255, 245 ) )
I'm not sure why it works, looking back at it. I think the light gray interacts with the background green color.
every other row is very pale green.every other row is very pale green.
