tcarrillo12
Custom Map
Hi, I've created this custom map but I cannot get the original plant drawing to overlay with the digitized image in the Graph Builder? Can anyone help? Thanks!!
Re: Custom Map
The issue is that the column name in the data table needs to be the same as the column name in the -name shape table.  You had specified "Name" in the -Name shape jmp table, but in the data table you called the column "Department".  I changed the column name to "Name" and brought up Graph Builder, and produced the following output:
Also, make sure you save the -XY and - Name data tables to the correct folders:
JMP looks for these files in two locations. One location is shared by all users on a machine.
This location is:
• Windows: C:/Program Files/SAS/JMP/12/Maps/
• Macintosh: /Library/Application Support/JMP/12/Maps
The other location is specific for an individual user:
• On Windows: C:/Users/<user name>/AppData/Roaming/SAS/JMP/Maps
• On Macintosh: /Users/<user name>/Library/Application Support/JMP/Maps
Re: Custom Map
This location is:
tcarrillo12
Re: Custom Map
Ho wow! Thank you very much. Now it worked for me. The only thing is that I cannot the original image to overlay with above. I noticed that on JMP help the author was able to overlay the floor plan drawing or image with the traced temperature.
