jjlx
remove Machine Data Source from list?
Does anyone know if it is possible to remove a Machine Data Source from the list of such in File > Database > Open Table, New Connection, tab Machine Data Source?
I have a couple of old connections to data sources which have since been migrated.  I would really like to remove them from the list since they are no longer functional.
Thanks!
Jennifer L.
Jeff_Perkinson
Re: remove Machine Data Source from list?
You should be able to do this with the ODBC Administrator​.
-Jeff
-Jeff
Jeff_Perkinson
-Jeff
-Jeff
jjlx
Right on!  Worked perfectly.  Thank you
