thenewguy
Custom JMP install without JRE?
We are a heavy JMP user and need to customize the installer to not include JRE as it is an outdated and vulnerable version.  Is there a way to do this?
-TNG
Re: Custom JMP install without JRE?
even it is a bit outdated question for future reference:
Running the installer you will come accross the selectioon what you like to install. There is the product as well as the JRE with a Checkbox for each. There you will be able to deselect Java Runtime Installation which cames with the product.
Hope that helps also future customers asking for the same thing,
Martin
/****NeverStopLearning****/
