glenn_turner
Silent uninstallation for JMP 11.x?
I've created a silent installation of JMP 11.2 by creating setup.iss files for both 11.1.1 and 11.2.0 setups and that's all working.
I need to also have the ability to silently uninstall JMP, but I need some help with the command-line
The interactive uninstall command-line is:
"c:\Program Files (x86)\Installshield Installation Information\{AA751FBF-FCBC-49E9-BCDF-220310781481}\setup.exe" -runfromtemp -l0x0409 -removeonly
I've tried adding /s, -s, /z, /q, creating a setup.iss and using /f1c:\%pathtosetup.iss%, even re-running the original installer with a response file, but nothing is working.  I'm getting prompted with "Do you want to completely remove the selected application and all of its features?"
Has anyone successfully suppressed this dialog box and silently uninstalled JMP?  I've checked the usual itninja site, and other installshield forums, but nothing helped.
glenn_turner
Re: Silent uninstallation for JMP 11.x?
Found the answer:
Create an uninstall.iss, then run it by using this command-line:
"C:\Program Files (x86)\Installshield Installation Information\{AA751FBF-FCBC-49E9-BCDF-220310781481}\setup.exe" -s -removeonly -f1C:\full_path_to_uninstall.iss -f2C:\full_path_to_uninstall.log
glenn_turner
Found the answer:
