Neo
Neo
Custom Group By Distribution Plots
I have two column data. Column1 is measured data from parts and Column2 lists Pass or Fail. I would like to plot the full distribution (Pass + Fail) for all the measured data and then stack below it distribution of only passing (Pass) parts. How, to get this working (JSL script would be fine but I would also like to know if this could be done interactively)?
At the moment, I find myself only able to group by Column2 in Distribution plot option and get a distribution for Fails and below it distribution for Pass (when stacked one below the other).
When it's too good to be true, it's neither
Neo
Neo
Re: Custom Group By Distribution Plots
Simples...
New Window("My Report",
Distribution(
	Stack( 1 ),
	Continuous Distribution(
		Column( :Col1),
		Horizontal Layout( 1 ),
		Vertical( 0 )
Distribution(
	Stack( 1 ),
	Automatic Recalc( 1 ),
		Column( :Col1),
		Vertical( 0 )
	Local Data Filter(
		Close Outline( 1 ),
		Add Filter( columns( :Col2), Where( :Col2== "PASS" ) )
8 REPLIES 8
tom_abramov
Level V
Copy column1 to column1_copy
Create distribution for both column1 and column1_copy
Add Local Data Filter of column2 for both of them (for column1 is not necessary but for simmetry of the charts will be nice)
Choose Pass only in the local data filter of column1_copy
Hope it helps.
BR,
Tom
Neo
Neo
Thanks @tom_abramov. I should have specified. I am looking for a solution without changing the data table.
You can build this interactively as a dashboard. This approach will also generate the script you would need if you want that.
Create your distribution of Column1.
Now Create another distribution of Column1, but add a Local Data Filter that is using Column2. Select the Pass group so that this report window now displays just the Pass observations. I would then collapse the Local Data filter area, but that is up to you.
In the lower-right of each of those report windows, check the box. Now from that same area, click the down arrow and choose to Combine Windows. This will give you both reports in one window, but they are arranged horizontally. Click the filtered report, and drag it to below the non-filtered report.
I think this will give you everything that you need.
Dan Obermiller
Neo
Neo
Thanks @Dan_Obermiller . This works and very useful trick to know. However, running the saved script does not reproduce the distribution charts one below the other. They still appear side by side. How to fix this?
I had not noticed that the script did not vertically arrange the plots. In that case I think that you will need to modify the script by putting in the appropriate VListBox to put the graphics into.
Dan Obermiller
Neo
Neo
@Dan_Obermiller . I do not see a JSL script inside when the combined chart is saved. It gives itself a default name of "Dashboard" which  when opened shows two charts inside. Where am I going wrong?
Neo
Neo
Here are my two scripts for full distribution and "pass" distribution respectively. Is there no simple way to put them in one chart one below the other via JSL?
Distribution( Continuous Distribution( Column( :Col1) ) );
Distribution(
	Continuous Distribution( Column( :Col1 ) ),
	Local Data Filter(
		Close Outline( 1 ),
		Add Filter( columns( :Col2), Where( :Col2 == "PASS" ) )
Neo
Neo
Simples...
Distribution(
	Stack( 1 ),
		Column( :Col1),
		Vertical( 0 )
Distribution(
	Stack( 1 ),
		Column( :Col1),
		Vertical( 0 )
	Local Data Filter(
		Close Outline( 1 ),
