joberi
Custom Design - I-optimal - center points not added
Hi All,
I just tried to design an I-optimal Experiment with 7 continuous factors with 48 runs. Within I'd like to have 6 center points. However, JMP does simply not include those, despite me entering those explicitly in the "Number of Center Point" field.
Any ideas?
11 REPLIES 11
joberi
Re: Custom Design - I-optimal - center points not added
Hi Dave,
so you got 6 center points?
That eventually means I am doing something different, doesn't it? Since it is not a complicated thing to make this design, I wonder what I am doing worng - any comments appreciated!
Concerning the manual addition of center runs: Thanks for your explanations!
David_Burnham
Yeah that's weird.  If you want I can make a video then you can do a comparison.  What version of JMP are you using?
-Dave
